Mitsubishi L200 Roll Cover Lock
Pajero
Definitely the lock can be replaced, pls show us how the setup looks from inside / underneath, that way I can suggest a locking barrel / cylinder to be used
Definitely involves small bit of fabrication here n there, but can be done
Ok thanks bro ill post pics here soon .... :grinning-smiley-003:
Can be done easily, for example
The attached pic setup
U need to fabricate these bits, a circular plate with calibrated holes, spoke based linkages to your locks, and a metal enclosure
to mount all this in,
you can use a generic toyota lock cylinder with key which is attached to the circular plate
Its not as hard as it looks, DIY or a simple bush mechanic can make this, find a barrel off panchi
You can even use a central lock actuator instead of the lock barrel / cylinder and motorize the thing along with the cabin locks, or wire it up as trunk release.
post-44236-0-77766300-1418234235_thumb.j
Edited by tiv
Thanks very much bro ....yeah the prevoius owner of the cab told me that this was motorized(he is the 1st owner imported personally from uk ,this lock was not there since he owns this) like it will automatically roll in and roll out by switching on/off, dont know he is correct but there seems to have two connections to the roller from inside the cabin
