Abs Warning Indication
chamila1986
My car is Toyota Premio 2007 NZT260.
My ABS warning light on dashboard have been indicating ABS warning(shows ABS warning light as log as car engine is running). I checked it with Toyota Lanka and they informed me that "Replace rear left hand side wheel bearing because it is not sensing". They informed me that it cost around 40 000 rupees.
Is this the only solution that I have? Are there any alternative solutions?
2 answers to this question
Rear hub bearing comes with the wheel sensor built into it and the senor alone cannot be replaced It is the only solution but you can buy the hub assembly and get it replaced from a place other than the agent for less than 40k. It is just a nut-and-bolt type job and does not require lot of expertise. I got the same thing done some two years back on a Vitz 2 years back for a price close to 10k. I
