Jbkumara
Engine oil
Hi
Am using shell 10w40 synthtic engine oil  for my hijet buddy van.
What if i use 10w 30 insted of 10w 40
Is it okey ?
Share this post
Link to post
4 answers to this question
10 hours ago, Jbkumara said:
Hi
Is it okey ?
What is the oil recommended in  your manual? No matter what the basses in service stations say, always only use the oil with the viscosity specified in the service manual.
Share this post
Link to post
A  controversial sub,
engine oils' have many viscosities as there are  openions.
Take into account  .the recommend oil for our operating conditions.  :angry-smiley-044:
TT.
Edited by Twin Turbo
Share this post
Link to post
@Jbkumara if your user manual specifies 10W30 is the recommended viscosity, then that's the one that gives optimal performance. But the important point to note is you may need a higher viscosity oil as the engine becomes older. How many kilometers has your van done (if you don't know the genuine number, make a guess).
The only 'difference' in opinion about engine oils we had in this forum was from a person who had confused engineering with economics and patriotism. However, even his opinion did not address viscosity but frequency of oil change.,
Share this post
Link to post
As ramishka and crosswind have said stick to the manufacturer recommended viscosity. Unless you feel that the engine is burning oil and the oil level is dropping, in which case use a slightly higher viscosity oil.
Share this post
Link to post
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign In Now
